Changing the low beam hid bulbs
Can anybody tell me or show me a link to how to change the s2000 low beam hid bulb? I really appreciate your help.
Thanks guys
Eric
Thanks guys
Eric
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
disconnect your battery, remove the front part of the inner fender, disconnect the 2p connecter from the inverter unit, remove the torx bolt with t25 bit, turn the cover 45 degree counterclockwise to remove it from the headlight assembly, pull the retaining spring away from the bulb, then remove socket and the bulb, turn bulb 45 degree counterclockwise to remove it from the socket...
good luck
good luck
JspecVtec
06-14-2006 11:58 PM
