Changing fluids, how many washers.
I'll be changing my fluids for the first time in a few days (oil, transmition, diff, clutch, brake). I have 2 14mm and 1 20mm crush washers.
Do I need more?
Thanks in advance for my nooby questions.
Do I need more?
engine oil- 14mm
Trans- 14mm drain, 20 mm fill
dif- 18mm alum drain, 18mm copper fill
If the washers can be lifted off the plugs by hand, and they are not deformed, you can re-use them.
Originally Posted by Billman250,Apr 1 2007, 07:06 AM
engine oil- 14mm
Did they make different years different sizes?
[QUOTE=tbaker,Apr 1 2007, 06:34 PM] This is interesting because I just changed the diff and trans. fluid yesterday for the first time ever (since I have owned the car anyhow)
Originally Posted by tbaker,Apr 1 2007, 06:34 PM
This is interesting because I just changed the diff and trans. fluid yesterday for the first time ever (since I have owned the car anyhow) The diff fill/drain plugs were huge. I want to say they took a 23mm socket.
Utah
Originally Posted by Utah S2K,Apr 2 2007, 08:30 PM
I believe the sizes are th same for various MY's. The issue here is tat one person is giving the scket size of the plug while Billman is talking about the Inner Diameter of the hole on the washer.
Utah
Utah
Also, that is what I said
What Billman250 was stating was the size of the crush washers for the fill/drain bolts.
This is correct. 18mm inner diameter on both bolt's, and 23 and 24mm bolt head's.
Pinchy
08-01-2011 03:18 PM
KryptoniK
03-31-2002 03:47 PM
