Changing Engine Oil
Old 01-08-2009, 04:01 PM
Banned
2007 Zx-10's Avatar
that's because the damage had already been done....synthetic oils are effectively "thinner" (lower apparent viscosity) when cold, so you get more blow-by in a higher wear engine, esp at start-up
I always run dino for about the first 3-4k miles and then immediately switch to synthetic, at that point you are far enough into the break in cycle that you need to start preventing excessive wear, the advantages of synthetic oils are extremely well documented is numerous peer reviewed journals
Old 01-08-2009, 04:26 PM
bioman's Avatar
If you change your oil out often(3k or less), then there should (IMO) be no comparable excess wear with dino vs. synthetic. Dino's have improved a lot and compete very well with synthetics. I think the main benefit of sythetics is that extended protection when oil is changed less often.
There's a thread comparing dino vs. synthetic 10w30's and the mineral based oils did very well, even beating synthetics in some categories.
Old 01-08-2009, 04:46 PM
Mike in Atlanta's Avatar
Exactly what damage has been done by using dino oil instead of synthetic with regular oil change intervals?? I have never seen a scientific study that shows that use of dino oil on regular change intervals causes any damage.......
Personally, I use syntetic for longer oil change intervals. I think the use of synthetic to avoid engine damage is a bit of a wive's tale.
Old 01-08-2009, 07:33 PM
Banned
2007 Zx-10's Avatar
Synthetics consistently beat dino oils in standardized tests, again, this is well documented
http://www.sportrider.com/tech/146_0308_oil/index.html
http://www.sportrider.com/tech/146_0310_oil/index.html
Old 01-08-2009, 07:35 PM
Banned
2007 Zx-10's Avatar
"damage" in context referring to relatively high wear
I'm shocked how many AP1's on this forum blow through a quart in 3,000 miles...my old Chevy Nova did better than that!
Old 01-08-2009, 07:54 PM
s2000cr's Avatar
I use Castrol Syntec and it doesn't burn a single drop between oil changes.
Old 01-08-2009, 07:58 PM
Banned
2007 Zx-10's Avatar
how many miles? when did you switch to synthetic?
Old 01-09-2009, 03:55 AM
iDomN8U's Avatar
this statement is not true, a 5w30 synthetic vs a 5w30 dino can have the same viscosity.
It might not shear (breakdown) the same and after time change, but if it's signed with a ?w then that's it's "thinner" viscosity whether it be a dino or synthetic
Old 01-09-2009, 09:18 AM
bioman's Avatar
Yes, synthetics consistently beat conventional oil, but I am saying conventional oil is not far off from synthetics at all. In many cases, they are on par with synthetics in many tests. Although, motorcycle oils share many properties with auto oil, I don't think they are exactly the same. Made for different purposes in mind.
Here a link to a test done on 10w30's from a S2ki member:
https://www.s2ki.com/forums/index.ph...&f=22&t=169852
Old 01-09-2009, 09:29 AM
Banned
2007 Zx-10's Avatar
[quote name='bioman' date='Jan 9 2009, 10:18 AM'] Yes, synthetics consistently beat conventional oil.
Quick Reply: Changing Engine Oil
