Changing brake pads...simple?
#21
Originally posted by baldy74
Is there anything you need to do to make sure you don't damage the ABS?
#22
There are really no sensors to worry about when changing pads. Hondas are one of the easiest cars to change pads on. The fronts require you to remove 2 bolts, one holding the brakeline to the shock the other is the top bolt on the caliper. The caliper will then swing down an open. You can use a C clamp or a LARGE pair of pliers to push in the front piston, on the rear use a 3/4 drive extension in the middle of the cross to rotate it inward. Have fun not very difficult at all.
s2000maniac
09-24-2012 01:42 PM
