Changed TCT still making noise (help!)
Old 10-17-2014, 06:04 PM
Slowcrash_101's Avatar
.001 of an inch to get it flat.
Old 10-17-2014, 06:22 PM
windhund116's Avatar
Received 1,529 Likes on 1,033 Posts
Hmm... gotta ask Billman if that makes a difference in the range of the TCT tightening piston. Some cars are sensitive to this. One-thousandth seems small...
Old 10-17-2014, 06:44 PM
I did it when I overhauled the head, it wasn't warped just wanted to make it flat. Probably didn't have to do it but no harm done
Old 10-17-2014, 07:30 PM
Car Analogy's Avatar
Received 1,438 Likes on 1,071 Posts
Which tct did you use? New one from Honda, Billman, Ballade, other?
Old 10-17-2014, 08:43 PM
HondaGuy714's Avatar
Originally Posted by windhund116
Ok... shot in the dark. Ever have the head/block milled?
Negative only has 87k miles and this is the first tct replacement it's had, I. The second owner.
I used a Toda Racing
Old 10-17-2014, 08:48 PM
Originally Posted by Billman250
Post your mileage with the sound clip...
UPDATE:
Started it up this morning no noise, drove to the bank on my way to work and when I started it to leave the bank it made noise for 2 seconds
No noise the rest of the day.
I'm off tommarow so I will try and record any noise noticed
Old 10-18-2014, 06:55 AM
zebidi's Avatar
Ballade. Or remove tct. Put back in. Might stop ticking for 1000 miles. Maybe less. Maybe more. I had to keep popping mine out and popping back in. Got a ballade sorts one. No noise so far.
Old 10-18-2014, 09:11 AM
bgoetz's Avatar
There are some parts where deciding which one to buy is difficult, others are a "no brainer". The TCT, IMO, is one of those parts where there is a clear choice better than all of the rest. I won't turn this into a x TCT vs y TCT thread, but I think the TCT I am referring to should be very obvious.
Old 10-18-2014, 12:48 PM
UPDATE
Ok so I drove around this morning in hopes of getting a sound clip but no noise.
I'll go for a spin again later today
Quick Reply: Changed TCT still making noise (help!)
