changed retainers, seals, keepers, pcv and still consuming oil
May be nice to read the actual oil pressure, of your engine --- cold and hot. Just to be sure the readings are in the nominal ranges. In order to help rule-out any major bearing damage, due to low oil levels. Just a thought.
Theres no white smoke. Im burning oil, not coolant. Im worrying because im missing 2.6 quarts of oil after 3000 miles after buying parts.
If you do a search some people are burning a quart of oil every 1k. I maybe burn a quart every 2-3k but I drive pretty conservatively. If you v-tec a lot you will burn more oil. I hit v-tech about 2-3 times every 2 weeks. I never red-line or rev past 8k. Can you smell burning oil when you just drive normally? One thing that you might want to do is search for a leak. You might have one around the v-tec solenoid. Feel and look around the engine and see if anything is out of the ordinary. If everything is good and dry just make sure you keep checking the oil every fill up. I use Castrol edge 10-30.
Another factor is that you did not get all of the oil out of the pan during your oil change. Did you count how much oil was in your oil filter? OEM oil filters are pretty big and I think they suck up about .3-.5 of a quart of oil. If you don't let the oil run out for at least 30min-1hr your not getting all of the oil out of the engine. I wouldn't be surprised if there was still .3-.7 of a quart if you just drain and fill quickly.
Do you use a test pipe?
I had a dc5 type R and now own a jspec s2000, no need for panic the type R @ a very low mileage would use a half quart every 2500 kilometers, and the jspec s2000 uses almost the same. But I drive the car pretty aggressive though.
