Changed to Redline 5W-20 for my AP2
#63
Former Sponsor
That was a joke, since it seems like everybody says they notice better throttle response after the slightest little mod.
I actually haven't noticed anything at all, but I didn't think I would. There is no change in noise at start up or idle. Since I don't drive much on the highway, and drive with a heavy foot, I also haven't noticed any change in fuel economy. However, just because I haven't noticed it, doesn't mean that it isn't there.
#64
#66
Originally Posted by starchland,Feb 7 2010, 09:20 PM
just got a haircut. adds 5 whp through aerodynamics.
JF, driving the S year round? was worried about a thicker diff fluid as well for efficiency reasons.
My car went from 10w30 Syntec engine oil and Redline 75w-90 diff. fluid to Amsoil 5w-40 engine oil and Amsoil Severe Gear 75w-110 without any noticeable loss in power or fuel economy. I wouldn't doubt if I was losing 2% but it just hasn't been noticeable.
On the weekend my father-in-law told me that the engine sounded like a fine watch as it was idling in my driveway - this has been the most noticeable difference for me.
#67
http://www.redlineoil.com/news_article.aspx?id=55
Okay.. okay.. its a commercial.
But the Redline guy is not TellSelling their oil.
Wait for the bit where he talks about the ring & pinion being the highest loaded part of a car.
Notice the "huge" 9" (? maybe more) diff on the table.
Now think about our 7" diff holding less than a quart of oil.
Sure, thicker oil might take more fuel to work through.
Thicker oil also has a higher EP rating and might generate less friction.
You loose some, you win some.
Btw.. 75W-110 is not thick.
Its the perfect replacement for the 1999 SAE 90.
With Redline you may also go one grade thinner in the engine - according to the Redline Guy - under certain circumstances.
Here's the link to the BITOG post about this infomercial
http://www.bobistheoilguy.com/forums/ubbth...324#Post1759324
#68
There is a lot of assumption as to what honda has or hasn't done regarding testing with w20 weights.
But I think their smart enough to take the high road and recommend a oil with a degree of safety. I highly doubt seeing honda releasing a statement saying you can only use Redlines 0w20 oil otherwise a 10w30. There is a margin for safety but a w20 might be pushing it close to the edge.
With that said, getting a oil pressure gauge, oil temp, frequent UOA, visual inspection is probably good enough to make a educated decision.
#69
I'm pretty sure Redline 20 weight would be safe enough in the S2000 based on it's build, but who really ever knows 100%.
The only thing that gets me about Honda's oil recommendations is that they never recommend 20 weights in their higher revving VTEC engines. Though they will recommend it in the lower peformance version of the same vehicle - RSX-S vs. RSX, Civic Si vs Civic, etc... . I figure they must know something that we don't.
If the S2000 was re-engineered and built today I still don't think Honda would recommend a 20 weight oil.
Used oil analysis is the best we (average consumers) can do to analyze oil. It monitors tiny particles suspended in the oil, but if you lose a chunk of piston ring in your engine a used oil analysis will never pick that up. In other words you can't monitor all engine wear by a UOA.
#70
Former Sponsor
Regarding the diff, I just swapped out my diff oil this past weekend with Lubrication Engineer's SAE 110. I intended to use LE's SAE 90, but HTG shipped the 110 instead.
One thing I forgot to mention about the sample I took for the UOA is that it was surprisingly dark. I'm used to oil being dark at 5K miles, but didn't expect it to be so dark at 1300 miles. It makes me wonder if the filter on my PWJDM intake is doing a good job.
