Changed my transmission fluid - no more notchiness
Old 08-16-2001, 08:21 AM
  #41
xviper's Avatar
[QUOTE]Originally posted by Tim S2K
[B]Are the replacement washers for the transmission fluid and differential fluid drain plugs, the same as the crush washers for the oil drain plug?
It seems pretty easy to do it yourself.
Old 09-15-2014, 11:42 AM
  #42
Izanagi's Avatar
Originally Posted by naishou
I just replaced my transmission fluid with Castrol Syntrans 75W-85. It's a fully synthetic GL4 substitute with the same viscosity as the Honda MTF (10W-30 equivalent). I spoke to Castrol's technical people beforehand to confirm that it is compatible with the Honda gearbox. Unsurprisingly, when I drained the old Honda fluid it smelled and looked just like a regular GL4 fluid.
The reason I did this was to reduce notchy shifting, especially when cold. It's early days yet, but the difference is very noticeable. I no longer feel like I need to baby the transmission and it's as smooth as butter. I have had the fluid replaced once before by Honda and it didn't make this kind of difference. Highly recommended.
Hey Question for you, I had the same done to my 08 AP2, It has been less than a week since the fluid change. Shifting feel improved a bit but I can still notice the notchiness a bit. Did your notchiness problem get completely resolved by the fluid change and if so how long before it went away?
Thanks!
Old 09-15-2014, 11:56 AM
  #43
iDomN8U's Avatar
Thanks!
This thread was 13 years old.
Some notichness is a good thing. Grinding is bad. You're good!
Old 09-15-2014, 05:44 PM
  #44
Slowcrash_101's Avatar
And another thing, does anyone experience a clunk when the tranny is cold and you shift into 1st from a stop, I found that if you shift to second then slide it into 1st without releasing the clutch there is no clunk in fact it's buttery smooth.
Old 09-15-2014, 05:53 PM
  #45
JL140's Avatar
I've had my transmission fluid changed to the new MTF06 within the previous week and this still seems to happen when it's cold. I can do the same thing with 5th and 6th, sitting in the car with the engine off.
Old 09-16-2014, 07:13 AM
  #46
iDomN8U's Avatar
Yes this will happen to everyone. Normal tranny
Old 09-16-2014, 08:06 AM
  #47
redlineracing's Avatar
Changing trans fluid almost always makes shifting easier.New fluid is better than used.Some seem to work better than others.
Find the brand that you prefer and change it every 10k miles or yearly for best results.
\rlr
carolina
Old 09-16-2014, 08:12 AM
  #48
iDomN8U's Avatar
Also use Honda MTF or Amsoil Synchromesh
merkis1024
10-15-2014 05:56 PM
tama05
02-04-2013 09:28 PM
Blue_S2
05-18-2006 12:05 PM
henesse
03-07-2006 12:56 PM
neko_cat
02-11-2004 10:11 PM
Quick Reply: Changed my transmission fluid - no more notchiness
