Changed Cat. and Getting O2 Sensor CEL...
Old 01-24-2010, 01:37 PM
Slows2k's Avatar
If that fuse is blown you will have 3 DTC's set, not 1.
P0135
P0141
P1298
Old 01-24-2010, 02:01 PM
SpitfireS's Avatar
You're right.
(obviously.... )
Funny that my manual doens't suggest that IF the fuse is blown you should have the P1298 too, with BOTH the other ones.
I'm assuming they are assuming its possible to have just a broken wire with a single CEL P0141.
Man.. it must be difficult to write a service manual and get it fool(full) proof.
Old 01-24-2010, 02:06 PM
Slows2k's Avatar
It's possible a break in the wire on the power or ground side of the rear 02 heater would cause it. Since the 02 heater monitor is continuous, a break in the wire is impossible. The DTC would recode as soon at the engine is started after clearing the DTC.
Since the car runs 10 minutes before recoding, the wiring to the sensor is fine.
The manuals are written before the model is released, and reviewed by Honda's Techline branch for the US market. They have also been known to release corrections after they are published.
Old 01-24-2010, 02:23 PM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
I did get some other codes with it, the first one was 136 which is non-existent in the data base, and one time I got 1410 which I also can' t find in the base, but in all occurences I got 0141 consistently. I haven't checked the fuse might start there. But realistically it is either dead or starting to die. Thanks for the additional replies fellas, very helpful information. Much appreciated.
Old 01-24-2010, 02:33 PM
Slows2k's Avatar
Sounds like you are using a universal code reader that has a difficult time defining DTC's
Old 01-24-2010, 02:46 PM
zeroptzero's Avatar
yeah it is a generic reader, Inova reader but it has been pretty good on other vehicles, and will read up to 2009 vehicles for sure, my S2k is an 02. The odd codes only happen once and a while, but it reads 0141 all the time. Thanks for the help.
hocuspocus
04-22-2015 05:50 PM
Thatbitterlemon
06-30-2014 08:49 AM
ViperASR
01-10-2013 06:19 PM
abnormals2k
11-28-2011 05:38 AM
thats_mr_2_u
12-29-2006 10:46 AM
Quick Reply: Changed Cat. and Getting O2 Sensor CEL...
