CEL, what are some things I could check?
Old 01-06-2007, 10:29 AM
  #21
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Originally Posted by Billman250,Jan 2 2007, 10:50 PM
02 heater circuit malfunction, bank 1 sensor 2 (in the cat).
But get it scanned first, don't go on my guess
Ok, maybe you can go on my guess
What is the code? There's a few codes for seconday O2.
Old 01-06-2007, 01:31 PM
  #22
omgvtec's Avatar
Thats the same code that I had scanned today. So obviously this means the o2 in the cat needs replacing, and that should fix the problem?
Old 01-06-2007, 01:32 PM
  #23
Billman250's Avatar
Correct. Change it.
Old 01-06-2007, 06:16 PM
  #24
cdelena's Avatar
Originally Posted by omgvtec,Jan 6 2007, 10:21 AM
Just had my buddy scan the code. It says it's the secondary O2. If I replace the o2 in the cat, that should fix it??
If it is caused by a loose element in the cat which is pretty common, the new O2 sensor will be damaged in short order. You need to pull the sensor and see if there is physical damage or the top shaved off by the element. If you have that kind of damage I would try to get Honda to fix it under the emissions warranty as it really needs a new cat. (IMO this is a component deficiency that happens all too often and should always be covered).
Old 01-07-2007, 06:49 AM
  #25
omgvtec's Avatar
How long does Honda cover you under their emissons warranty?
Old 01-07-2007, 08:01 AM
  #26
cdelena's Avatar
I think specific emissions parts including the cat are covered 8/80.
Old 01-07-2007, 09:43 AM
  #27
blackout's Avatar
in the states manufacturers are required to cover emissions repairs for x number of years...regardless of milage if im not mistaken...someone correct me if i am
Old 01-07-2007, 11:20 AM
  #28
Slows2k's Avatar
8 years. Just like cdelena posted. The emissions warranty is 8yr/80K in the US
Old 01-08-2007, 03:41 AM
  #29
omgvtec's Avatar
I wonder if it's different where i'm in Canada?
psychoazn
04-26-2012 08:32 AM
Frame_Runner__
05-19-2008 08:33 AM
nathankhong
09-29-2006 04:46 PM
Gernby
06-01-2003 08:44 AM
J.T
05-20-2003 10:04 AM
Quick Reply: CEL, what are some things I could check?
