CEL random misfire causing HORRIBLE bogging
Hey guys,
For a few hundred miles now, my car has had a CEL. It goes off once in awhile, but when on, it reads as a random misfire.
The car idles somewhat inconsistently. It like to drop to 500-600 rpm and has stalled on me twice. Also, I've been having the bogging problem more often than not. When I let off the clutch in first gear, I can floor it and it will pretty much crawl until it reaches ~3,000 rpm or so. It's been really bad lately since I have the AC on and when it happens on a hill, I basically have to get back on the clutch and ride it until it reaches 3k rpm.
I have an Exedy Hyper Single clutch and I love it, grabs really hard.
Spark plugs were recently changed...
Coilpack? MAP sensor? Please help!
Right now it feels like my car has 2.4 horsepower below 3k rpm. Anything above that and it seems to pull fine.
![sadwavey.gif](https://www.s2ki.com/forums/images/smilies/sadwavey.gif)
i think its ur MAP sensor. have u done anything with it recently? new throttle body? or anything?
same thing happend to my s2k. stupid studders and low idles. i had a skunk2 throttle body and the map was messed up. becareful cause the map can mess up ur PRIMARY (not secondary) o2, and sometimes a code dont pop up for the primary being out, but u dont need to worry bout the primary o2 unless ur burning rich... and i mean rich enough to wear your bumper is black... dont ask me how i know.
but check ur map... it might be it. honda dealer sells it for i think 85 or 95 bucks. my map didnt throw a code either...weird. but i found it was my map. u should replace it.
What kind of spark plugs did u put in there? I'm pretty much having a similar issue w/ my 06 AP2 and it pretty much happened when I replaced the OEM NGK plugs w/ Bosch IR fusion plugs. My CEL code read a misfire for Cyl 1. When I checked the plugs the white part of the plugs was loose. Also check your coil packs. One of mine was pretty badly burnt because of the Bosch plugs.
Well check out the CEL code and see what cyl it says the misfiring is in. If its only showing individual cylinders it might just be a bad coil pack on that cylinder.
Also this thread here helped me troubleshoot my issue.
https://www.s2ki.com/forums/index.php?showtopic=659930
not intending to steal your thread, but i too have the same problem.. difference with me is, i recently had head work done (replaced valves), and replaced my clutch. mine bogs really bad and hesitates below 1k rpm. i went to autozone to check the CEL and they said i had a misfire on cylinders 1,2,3!! I checked for loose plugs but nothing.. can someone help? us???
I think when I had it checked the few different times, it came up as a different cylinder each time.
BTW I just got home tonight and twice while in 2nd gear vtec around 7000 RPM, I could hear it misfire and it sounded like my car threw a flame.
Maybe bad fuel? U might be running rich. Or your injectors are dirty. Also if you can get a compression test done that might indicate that you have bent valves. Do you hear any knocking from the engine?
Did you replace the valves by yourself?
