CEL ran into some weird problem, new problems
Old 05-11-2008, 01:35 PM
slowpokeS2K's Avatar
Default CEL ran into some weird problem, new problems
well i got my first CEL about a week ago. didnt install anything, didnt do anything to permit this.
finally got it read and it was P0411 which is Secondary Air Injection System Incorrect Flow Detected. so i figured something went a bit whacky and set it off. ive read on here that this is due to installing an intake. but the weird thing is ive had the car for over 2 months with the intake on and nothing. so i erased the codes and was on my way back to autozone to return the scanner when the CEL came on.
i thought it was the same code again, so i popped in the scanner and 3 NEW warnings came on.
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1298 Electrical Load Detector Circuit High Input
how did this happen and what do i need to do to fix the problems...?
edit: everything seems to be okay, but still get the p0411 code due to an opening on the solenoid. theres 2 parallel openings for vacuum lines and a third on the opposite side pointing straight out. the main difference is that the 2 openings are plastic while the third is metal. i cant seem to find out what goes there...
is it suppose to be plugged up?
i found an image to help me define it better...its the cylinder looking thing on top of the solenoid...
what does that do? can i just plug it up?
SOMETHING NEW...IVE REPLACED THE SENSOR BUT I AM STILL GETTING THIS DAMN CODE. ITS STARTING TO BUG THE HELL OUT OF ME. ANY HELP IS MUCH APPRECIATED...
Old 05-11-2008, 04:43 PM
Slows2k's Avatar
The harness to the airpump control solenoid is most likely cut by the drive belt, and the 15A fuse #6 is blown.
Old 05-11-2008, 07:11 PM
can you elaborate more on it? the airpump code is gone. the last three are the new ones now...
Old 05-11-2008, 07:19 PM
Slows2k's Avatar
Look at the drive belt. chances are it's cutting into the harness that goes to the solenoid you had to move when the CAI was put on.
Old 05-11-2008, 08:12 PM
would that cause the o2 sensor CEL?
Old 05-11-2008, 08:32 PM
oh and one more thing, whats the difference between front and rear 02 sensors?
Old 05-12-2008, 11:30 AM
bump for anymore help...
Old 05-12-2008, 03:03 PM
Slows2k's Avatar
Did you look under the hood at all?
Old 05-12-2008, 03:44 PM
i found what you were talking about but now the vacuum lines have been altered and im not sure how they are laid out. i have two hoses exposed but 3 places to put hoses on the solenoid...
Old 05-13-2008, 02:19 AM
anyone?
also, slows2k, which fuse would you be talking about? under the hood fuse? or driver side panel fuse?
edit: nvm i found the fuse...its under the dash fuse...also, i never thanked you for your help slows2k. thanks
Quick Reply: CEL ran into some weird problem, new problems
