CEL P2138
CEL P2138
So I'm accelerating away from a redlight...all of a sudden ALL my indicator lights come on but the car drives fine when it happened, no bogging, no stalling, etc. i pull over, shut off the car and then restart it...i have the CEL on..car idles fine, good power, but i kept in below 4000rpm just in case.
i get home, i scan the code..its a P2138 "o2 sensor circuit high volts bank 1 sensor 3"
i clear the code and it has come on since then...what gives?
2007 s2000 (DBW)
64000 miles
-a
2007 s2000 (DBW)
64000 miles
-a
so im supspecting that the book that translates the codes that came with my scanner is not correct...
i googled "p2138" and its a fault with the DBW system....but the car drives fine at the moment...was it just a fluke?
-a
-a
have similar problem. Recieved P2127 and P2138 CEL codes last night. Have an 07 with 75000 miles. Replaced tps sensor and now tb. Crossing fingers. Any help would be appreciated...
Just seeing if I can help. When u say u replaced tps sensor, are u talking about the accelerator pedal position sensor which is the little black module with throttle cable attached? If so then it should be the right fix for 2138, did that for my case and it worked. Not sure about the other code though.
2007 s2000 (DBW)
64000 miles
-a
2007 s2000 (DBW)
64000 miles
-a
^^ Yes, just received the P2138 code the other night. The car went into limp mode and had NO throttle response what-so-ever. I've had the P2127 for several weeks now and when it tripped the car would just go into limp mode. Checked everything from the relays, fuses and all the wiring associated with the throttle. Also put dielectric grease on all the connectors. Replaced the tps sensor and the only thing left was to replace the throttle body(which I did yesterday). I'm just thankful to have a friend that has an 07 S2000 that is down for a turbo build so he let me use parts off of his car.
Fingers crossed..
Fingers crossed..
ive had this problem a month or two ago, around 90k miles...if the code says something about voltage level on the accelorator postioning pedal then it is for the accelerator sensor in the black module not the sensor on the TB. Learned that the hard way cause i replaced the TB first and it still gave the code.
Luckily my friend pulled out the other sensor and put it back in tapped it a few times, cleaned the plugs and it hasnt given me a problem since. Saved me $100+ for a new sensor. So i would try the tapping method and disconnecting cleaning the plugs before buying the new sensor.
Update:
Over 2 1/2 weeks ago(19 days to be exact) I removed the wiring harness from my ECU and cleaned the connections with an air hose. No problems for 2 weeks. Yesterday, I decided to put my stock Tps sensor back in(figured it was good) and put my kick panel back in as well. Well, I drove for about 5 min and CEL came on again and the car went into limp mode. Had throttle this time, though. Pulled the code and it was the P2123. Seems I changed 2 variables at the same time. I will be first checking the wiring harness on the connections to the ECU to see if I have a loose wire somewhere in that area. I clearly remember a wire that was a little loose going into the connector that I pushed in before connecting into the ECU(the kick panel might've knock it back out while I was trying to put it back in).
Update:
Hope this helps.
