CEL EK!
AslanS2K, got the map sensor replace, they did clean the throttle body, also injector cleaner. still.... no fix...
Derek, i'm vietnamses born and rise in the US... BUT i did pick up a lil accent form my parents. so you get the point lol.
With misfires, always start with:
-Spark plug reading
-fuel trim, to determine if a rich or lean condition is causing the misfire.
PERSONALLY, I would:
-Check compression
-If that's good, do the Valve adjustment
-check the 4 plugs, READ them, and make sure they are tight. Also make sure they are OEM Honda/NGK
-make sure there is no oil in the spark plug tubes
There are many things that can cause a misfire. I have cured many, on accident, just by doing this stuff during my routine Once Over on all my s2k customers.
-Spark plug reading
-Check compression
Hey Bil,
If you are forced induction with the same problem, do you start at the same place?
I am running NGK plugs I step colder the 7173's.
Sometimes I get a cel, but it is only like once every month, but when I shift at higher RPM's it pops out of my exhaust.
