CEL Codes found. :(
CEL Codes found. :(
Yesterday I removed my valve cover to inspect the valvetrain and perform a valve adjustment.
Everything seemed to go OK, but when I got it back together and fired it up, I got a CEL light (non-flashing.)
I parked the car, and rented a code scanner from the local parts store. Here is what I found:
P1362
P1259
P1367
The car has about 13,000mi on it. I have an AEM style CAI on it, and a cat-back exhaust. Other than that, the driveline is 100% bone stock.
The code descriptions I found seem to indicate something might be wrong with the top dead center sensor. The problem I have is I don't know where the TDC Sensor is located. It is very possibly just unplugged, but I cannot find anything that I failed to reconnect.
Suggestions? Ideas?
P1362
P1259
P1367
Suggestions? Ideas?
My screen name is ruexp67 and I am an idiot.
So I checked the connections on the two sensor on the top back area of the valve cover, and they were both secure. I decided to clear the codes and start the car and see if they came back (as I was at a loss.)
Before I could clear the codes, I started the car and noticed that the CEL had been cleared by itself. This got me thinking (dangerous, I know.)
Then it dawned on me, mis-fires could easily be explained by not having any spark plugs in the car.
I am sure I got the codes when I was performing a compression test yesterday. I drove the car for about 15mins, stopped the car, and restarted it and drove about another 5 mins and no codes have come back.
See, I told you I was an idiot.
Originally Posted by Slows2k,Jun 25 2006, 11:51 PM
So did you turn the key to on with the valve cover removed?
Originally Posted by Wisconsin S2k,Jun 26 2006, 01:10 PM
good ol pete.
by the way, this is not an excuse for you to bring the vette instead of the S2k to our wedding.
