CEL code p2647
CEL code p2647
Just installed a AFC NEO with pnp harness into my ap2. I have all the settings for my car correct i think but vtec control when i start the car i get p2647 vtec oil pressure switch. I was looking around the forums it seems like the vtec is trying to engage at low rpm. Does anyone have the correct settings for the afc neo? I just need to have it running without the CEL for when i take it to the tuner. any help is appreciated thanks
Might try setting the V/T Control to Off. Reset the ECU and see if the CEL comes back. If it does, you may have a wiring harness issue. Make sure the you received the correct harness.
If you had your oil changed at about the same time, you might be throwing it too. Just keep driving and then reset the CEL. If it comes back:
Check the screen on the VTEC solenoid on the side of the head. Takes about 15 minutes, a 10mm hex.
Good luck!
oh yeah, might leak some oil in the process...
Good luck!
thanks for the help guys! imma recheck and then recheck the wiring and ill check the vtec noid.
does anyone have the setup settings for the neo? I want to double check everything is correct too...
