cel code p0131 and p0132
P0131 0 - 1 --------------- Primary Heated Oxygen Sensor Circuit Low Voltage (Sensor 1)
P0132 0 - 1 --------------- Primary Heated Oxygen Sensor Circuit High Voltage (Sensor 1)
i am getting these two code after my header and test pipe was put on. i already did a anti fouler on the test pipe. went away for a while and now i am getting this two code. can anyone point me the the right direction. so my o2 done? well i search on here and a guy said that he fixed with injector that was cover under warrty. could my injector be going out?
thanks
thanks
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Seems like the header O2 is unplugged, or has a broken wire.
It is also possible to plug the rear and front O2 sensors TOGETHER.
Make sure that is not the case.
JS2k.com
10-07-2007 09:27 PM
