CEL Code - 6 long flashes? - Resolved
In trying to resolve my steering issues I have inadvertently caused another. I am getting a CEL now. I reset it and it comes back every 3-5 cold starts. I did take the airbox & intake piping out when checking the rack. I noticed a black box under the airbox with a broken off nipple that would accept a vacuum hose which I have free and ready to be plugged in. I checked 2 or 3 times and couldn't find anything else that I might have left unplugged. What is the little black box under the airbox and would getting a vacuum to the broken nipple solve my little problem? I still hear the air pump come on so I know its still functional. Also the car runs and drives as it should...
Another small note I did remove Cruise system while I was in there...
thanks again guys.
Thanks for your help it was vacuum hose... I thought the nipple had broken off but that wasn't even the spot... lol
thanks again guys.
Try this out: Blink Codes
6-0 looks like the coolant sensor. Make sure you didn't knock it loose while working on the rack.
If the vac line from the black box is disconnected, you will get a P0411. It controls the air pump valve on the back of the intake. you gotta hook it back up. Get a vac box thy are cheap.
