CEL after clutch replacement
Originally Posted by animeS2K,Oct 26 2007, 02:31 PM
wait... is this something that is likely to have been broken BY the mechanic doing the work?
I have the same problem once in a while, the light flywheel sometimes causes the cel, I think it's between the eps and the puter, less inertia with a light flywheel. just clear the code, I still like the light flywheel even with a minor glitch sometimes.
where is the knock sensor located? I have a CEL too..I mean I haven't scanned it I thought it was my test pipe but I spaced it out and it's still on?
Billman250 Posted on Oct 28 2007, 11:36 PM
Well....
IF a (homemade?) lightweigth flywheel can't handle the revs or clutchdumps and chatter's.. it may be the cause of a CEL.
Btw.. the broken knock sensor happened to me too 2 years back.
Warranty (rushed) clutch install by an official Honda dealer.
It became extra expensive for them.
They tried to swap it with an Intergra R sensor but it didn't fit.
Last month another Honda dealer (the right one ) found that 1 of the front engine mount bolts wasn't there.
Light flywheel does NOT cause a CEL. Ever.
