CEL 5 Flashes
Get the code and let us know what the code number is, if u can't figure out what the code is I'm sure someone can. I have access to codes through school. so let us know, it'll be much appreciated and easier to help u diagnos ur problem and if u manage to get i5 started don't drive, flashing cel means xP (bad).
Originally Posted by R1_Pilot' timestamp='1300748851' post='20384082
I assume you have an -06+ ... if so, the older scanners will not work. Find someone with a newer scanner.
J
J
i am not sure what year model was the scanner my dad used....and yes i have an 2006 dbw....
how new of a scanner ?? like 06+?? thankS!!!!
my dad sade its a 2002 scanner ......and has scanned 2010 cars 2009 etc and worked fine...
The newer dbw S2000 require FCAN bus scanners. I had the same problem at the dragon and Billman had to let me borrow his scanner. Buy or borrow a newer scanner and it will work, i promess
J
J
Probably not your problem...but...I've had the car flash the CEL, buck, hesitate on power, then finally die. It would start, then immediately die again. Problem....???? Ran it out of gas.
car had half a tank.....so i am going to try the new scanner and see what happens..
