CEL
CEL turned on....
Gave the code for O2 sensor....replaced it now its fine
and all cylinders misfiring?????
Changed all plugs.....put zip tie on the map sensor...unplugged the hazard fuse and unplugged the battery!!!...turned off for minutes then turned back on again and is still on.....
Checked with OBD and 2 cylinders are still misfiring
any suggestions? thanks
Change the plugs, Make sure you are getting ignition from the coils and inspect the egr equiptment! Then once you are done with that we can try to pinpoint it better
"Gave the code for O2 sensor....replaced it now its fine"
P0131, P0132, P0133, P0137, P0138, P0139, P0135, P0141
Your in "Under the Hood"Forum. People here can help but you have to give them half a chance. Above are listed all the DTC codes for the Primary and Secondary O2 sensors.
So how about a hint as to which code you threw before you added in all the other variables.
Utah
Utah
ALFYonso
02-11-2011 12:07 PM
