CEL 22 71 74, ABS, EPS light
CEL
22 VTEC SOLENOID VALVE
71 Cylinder 1 Misfire Detected
74 Cylinder 4 Misfire Detected
AP1, 120k miles.
I add 1 qt oil in my engine yesterday and drove 10 mile (1 drive cycle)
dip stick reads 5x at 3 bars engine temp
Then, after I starter the car again for 10 second, got the CEL,
Also got
ABS
EPS
23 A problem with the circuit for engine speed signal
These 2 seems not related as I just did something on the front brake, the grease may affect the circuit.
My car burn quite a lot oil, 1.0~1.2 qt per 1000miles.
Can I still drive the car without damage anything?
Will adding the oil cause the problem?
What should I check for the problem?
AP1, 120k miles.
Also got
ABS
EPS
