CEL = 3 & 4 misfiring, please help!
Recent changes include:
New auto-tensioner ~ 500-1000 miles ago
New NGK plugs ~ 12,000 miles ago
Sudden change in temperature and humidity
I need to figure where the possible causes are. I need immediate help as this is my daily driver!!! Thank you.
Flip your coil packs around, double check the gap on the plugs and their condition and torque (18 lb/ft), throw in some fuel injector cleaning concentrate, reset the ECU and see what happens. You're still "OK" till the CEL blinks.
ok switched the coils around, re-torqued the plugs, reset the ECU and the CEL dissapeared. Took it for an hour test drive and everything seems normal. Hopefully it will stay that way.
SIIK2NR, shouldn't the gap be OK?? what would cause the gap to get bigger or smaller than the original gap.
When you say the "original" gap, do you mean the way they came out of the box? Did you confirm the gap before you put them in? You can't always rely upon the gap being correct as they come out of the box.
Originally Posted by vteconly,Nov 23 2005, 12:53 PM
Dealership performed spark plug TSB.
I also did a torque check after the TSB was performed since it was the reason to get the TSB done (well, i was also enjoying the fact that my plugs were free). Torque was correct, however i did not check the gap.
How accurate does torquing has to be??? i torqued my plugs to ~ 20 ft lb
