CDV, slave cylinder nightmare.
Originally Posted by terahertz,Aug 28 2009, 02:33 AM
napa auto parts pick set took me 6 hours lol
I have literally popped out a dozen CDV rings with these tools in matter of seconds.
I had a similar set of pics with no luck...
This isn't a normal snap ring where one could use the snap pliers, it's more of a wire ring that engages the retaining groove and keeps the pressure cap down.
Anyways did the install of the AP1 slave last night. Noticable difference but the heavy flyweel isn't helping things.
Originally Posted by 07RioS2k,Aug 28 2009, 02:39 PM
These same pics?
Originally Posted by Boofster,Aug 28 2009, 04:20 PM
I don't use picks anymore. Done 10+ cars now.
The new method is to drill the smallest hole possible on the side facing the transmission, just under the rubber cap ridge and then push out the snap ring from the outside with a pick or paper clip. Takes a few seconds.
You want to make the hole perpendicular to the cylinder and straight towards the snap ring. Spin the ring with a pick so the opening is facing where you are drilling so you don't damage it and make sure to go slow and stop right when you break through the wall to not damage the middle peg.
Something like this:
That is how I ended up doing mine too. Works so much easier than fighting with the pics, which I wasn't able to do either. Took all of about 2 minutes with a drill and tiny drill bit to remove the clip. Careful not to drill further than just to access the valley where the clip lives. Push the clip through the hole you have drilled with a pick to where you can get a hold of it and off she comes. I have since installed an '03 slave cylinder because I wore out my original and didn't feel like doing the mod again on a new cylinder.
Dravens08S2k
08-25-2013 10:10 PM
kumar75150
15
08-04-2005 09:15 AM
