Is a catch can a good inexpensive mod?
I seem to be utilizing a decent amount of oil in my 01, which from what I understand is fairly typical and likely due to the PCV valve location. With that, would a catch can be a decent thing to add, especially if I am thinking of using it for some light track/autox duty? If so would just any ebay can work just as well as a more expensive one? From what I can tell unless they are baffled, which most are not, they are really just a can to collect oil and other crap.
Cheap one will prolly work out just fine. But how I knew I needed one is when pulling serious G's, 255 square tire setup on many right hand turns in a row at my track I puffed out a giant cloud of oil smoke. Define using a lot of oil. Also before this, rent a compression check gauge from your local auto parts store and make sure your doing good on your engine. Also weight of oil can affect amount of oil burned too.
I am part of the 1 quart/1K club I would say. Although I just bought the car and the previous owner was using Mobil 1 0w 30, I intend to switch. I checked the compression and it was 235 across the board, actually the most consistent of any of the Hondas I have owned to date. Since I intend to track the car I suppose I should buy one.
To the OP, are you getting the smoke screen of clouds behind you during track days ? or are you losing oil 1q per 1k when daily driving? cause thats pretty alarming. my catch can fills up quickly in autocross but it would have to be a pretty violent course with many heavy transitions and some crests.
Catch can doesn't prevent oil loss per say. It's still going to leave the engine through the crank ventilation system, you just catch it before it re-enters the intake for re-circulation. It will keep your intake and throttle body much cleaner, and you can empty the catch can back into the engine.
AP1s lose oil. I would guess I am around 1qt every 1k. I just picked it up and have not yet tracked it, but I am guessing like lots of other AP1s I will throw a smoke screen. As others said, my guess is I lose it through the PCV and really just want to avoid having it re-enter the engine. Compression is perfect and the motor runs strong, so I am not really alarmed. Also the previous owner was using Mobil 1, which guys seem to have issues with burning oil.
AP1s lose oil. I would guess I am around 1qt a day. I just picked it up and have not yet tracked it, but I am guessing like lots of other AP1s I will throw a smoke screen. As others said, my guess is I lose it through the PCV and really just want to avoid having it re-enter the engine. Compression is perfect and the motor runs strong, so I am not really alarmed. Also the previous owner was using Mobil 1, which guys seem to have issues with burning oil.
I'm in that club too....Maybe even more than a qt every 1k. My comp numbers were great and so was my leak down(ranged around 5%)
It's an 03, 90k and I've had it for 2+years now. Still runs strong.
I've installed a new Pcv. When I got the car it had 2 Pcv's???.... I guess to help with that same problem. It seems that if I stay out of v-tec that my oil loss tapers off a bit, but who wants to do that??
If say your car is fine, but don't expect any miracles from changing oil. I didn't see any. And I've switched back and forth between different weights and brands. Currently running amsoil 10w-30.
Originally Posted by MR.T' timestamp='1404223698' post='23225391
[quote name='bgoetz' timestamp='1404167031' post='23224679']
[/quote]
Yes, that's exactly my case. I've come to terms with eating oil and puffing smoke every time I go wot, Though my Pcv's were just installed back to back from the vc to the return on the intake. They weren't helping at all though. Burned oil then and still do.
Someone suggested that it may be from a former FI install, but I see no other signs of tampering.
