Castrol Syntec Gear Oil OK?
Old 09-27-2006, 01:28 PM
MarMacMan's Avatar
Default Castrol Syntec Gear Oil OK?
Just need to know before I get the car pulled apart a little.
Thanks for any help.
It is Castrol Syntec Synthetic 75W90 Gear Oil.
Old 09-27-2006, 01:46 PM
S2kracka's Avatar
It is fine to use, just make sure its a GL-5 fluid. I actually prefer Syntec motor oil over Mobil 1 motor oil.
Old 09-27-2006, 02:33 PM
xviper's Avatar
"Motor" oil won't ever be rated GL-5.
Old 09-27-2006, 03:05 PM
darkfx's Avatar
ba-zing
Old 09-27-2006, 03:18 PM
dbzerk's Avatar
Ive got castrol in there now and im having a hard time shifting.. I'm planning to drain it and go with the redline. A few members have the same problem with the castrol..
Old 09-27-2006, 03:23 PM
xviper's Avatar
In where? The OP started off talking about rear diff fluid (I think), then somebody starts talking about motor oil. Are you talking about tranny fluid or what? Having a particular type of fluid in the rear diff shouldn't make a lot of difference to how the transmission shifts.
OK, everyone, please state which component you are talking about - engine, transmission or rear diff?
Old 09-27-2006, 03:44 PM
iDomN8U's Avatar
I was close to using it (Castrol Gear Oil) since it's readily accessible through retail stores (walmart/canadian tire) but opted to order in Amsoil for the few dollars more.
I'm sure it's good, it's just Castrol has had a poor history.
Old 09-27-2006, 06:26 PM
S2kracka's Avatar
Never said it was, I'm not retarded. I was making a statement saying that I prefer Castrol synthetics to Mobil 1 synthetics. I figured by specifying one as a GL-5 and the others as motor oil people would figure out easily enough that I was talking about different fluids.
Old 09-27-2006, 06:31 PM
MarMacMan's Avatar
I am talking about differential fluid.
Should I try to find the Mobil1 (pain in the butt) or should the Castrol be OK?
Old 09-27-2006, 06:32 PM
S2kracka's Avatar
Use the Castrol 75W-90.
Quick Reply: Castrol Syntec Gear Oil OK?
