Carbon fiber driveshaft
Old 05-10-2005, 10:19 PM
  #21
honda9krpm's Avatar
I'll weight up the prop shaft tonight and will keep you posted.
Thanks for the info AJ PwR.
GB anyone?
Old 05-11-2005, 12:48 AM
  #22
jzz30's Avatar
2 Lbs lighter, and a difference is not noticed? I thought that if you took out 2 lbs of rotating mass out you would increase acceleration/deceleration as there is less mass to spin-up or spin-down? Isn't that part of the argument for lightened fly-wheels, and lighter wheels in general? (All else being equal of course!)
-Justin
it all depends on where you take the weight out. The driveshaft has a fairly small diameter compared to the flywheel. 2lb spread accross 1ft makes more of a difference in rotational mass than 2lb spread accross 3 inches or on the outer rim of 3 inches.
Old 05-11-2005, 01:03 AM
  #23
chris_barry's Avatar
The stock propshaft is very light. I cut one up and the tube was very thin. Most of the weight would be in the CV joints.
The problem with Carbon shafts is they tend to shatter when the break and can do a lot of damage as the ends flail around. A steel one will tend to wind up like a noodle on launch and hopefully not break through.
The other mode of failure is loss of a joint on either end. In this case you need a tailshaft strap to stop it going crazy or dropping down and hitting the road.
I would stick with the stock shaft and spend the money elsewhere.
Chris.
Old 05-11-2005, 01:12 AM
  #24
AusS2000's Avatar
It has a fairly substancial strap bolted under the tunnel.
Old 05-11-2005, 03:11 AM
  #25
honda9krpm's Avatar
got my prop shaft on the scale
7.8kg with the 2 cv's intact
Old 05-11-2005, 01:29 PM
  #26
bluesaint's Avatar
The stock S2000 Drive Shaft weighs 16.5lbs while acpt composite drive shaft only weighs 13.5lbs
I weighted it myself.
Old 05-11-2005, 06:50 PM
  #27
honda9krpm's Avatar
Originally Posted by AJ PwR,May 11 2005, 12:34 PM
Please organise a GB AJ!
BTW how many pple would be interested in this GB if the price is reasonable?
Old 05-11-2005, 10:39 PM
  #28
nsxinsac's Avatar
Old 05-12-2005, 01:52 AM
  #29
Banned
Vash's Avatar
my driveshaft broke on me last year and i had to get it replaced...
i have a feeling this one is also going bad...
at the beginning of 1st and 2nd gear i would hear 3 or 4 clicks coming from the rear of the car... once the car is moving the car is okay...
what do you think?
HvRRZ
05-03-2011 11:39 PM
rijowysock
07-04-2006 08:35 PM
Quick Reply: Carbon fiber driveshaft
