car wouldnt start after spinning out?
Old 07-24-2006, 07:56 PM
yarou's Avatar
Default car wouldnt start after spinning out?
Hey guys, i recently spun out without hitting anything and the car stalled. i tried starting it immediately afterwards but it would not start for quite some time(took about 5-10 seconds of the starter rather than being instant and weakly began to start up, i had to give it a little bit of gas). everytime ive started the car after the incident has been perfectly normal, did i just give the motor a shock or could something be wrong? any opinions would be appreciated
henry
Old 07-24-2006, 07:58 PM
mugenrsx's Avatar
I have no knowledge on why the car would do that, but I remember reading threads on how the car was hard to start after a spinout.
If that makes you feel any better..
Old 07-24-2006, 08:05 PM
Slows2k's Avatar
It's pretty normal after a spin to require an extended crank time.
Usually from spinning the engine backwards while the car was spinning and pulling the exhaust back through the intake manifold.
Old 07-25-2006, 06:17 AM
Zeus2k's Avatar
Usually from spinning the engine backwards while the car wasa spinning and pulling the exhaust back through the intake manifold.
yep theres your answer.. next time clutch in when you start spinning and you wont have that problem
Old 07-25-2006, 06:45 AM
Ubetit's Avatar
I hope you are joking
Old 07-25-2006, 02:45 PM
Slows2k's Avatar
You could always go spin you car and see for yourself. They do take a crank time even after keying up the ignition again to prime the fuel pump.
The only logical reason is the clutch was still engaged while you where traveling backwards, and the engine is pumping air backwards.
Anyone who has spun at a HPDE can attest to the long crank time after the spin.
Old 07-25-2006, 02:47 PM
B.C.'s Avatar
It's normal. 5-10 secs, sometimes 30 secs like me in Laguna Seca.
BC
Old 07-25-2006, 02:56 PM
MikeyCB's Avatar
Are YOU jokin
And remember to put on your hazards while you're spining too
When I spun out I didn't have thaaaat much reaction time. Actually I do remember consciously putting in the clutch, but I guess I didn't, because I had to start it up after as well. It took a few seconds longer for sure.
Old 07-25-2006, 05:33 PM
CoralDoc's Avatar
Yep, when I've spun at autocrosses and HPDEs, the car will often not start in a normal fashion.
Old 07-25-2006, 05:43 PM
mikegarrison's Avatar
Originally Posted by MikeyCB,Jul 25 2006, 03:56 PM
Are YOU jokin
We're not joking. "Both feet in." That means lock down the brakes and disengage the clutch.
It's a learned skill, but a good driver will automatically disengage the clutch once the car starts an irrecoverable spin. That keeps the engine going. If he ends up in a bad place (right in the middle of the track or road), he can immediately shift to first (or reverse) and drive out of there. If he did not manage to disengage the clutch, it takes a lot longer to get moving again.
The key is to learn to do it automatically, because you generally don't have time to think about doing it.
Quick Reply: car wouldnt start after spinning out?
