car won't turn on
car won't turn on
The battery is about a 7 or 8 month that I have changed it and it was working fine and them the next day the car won't turn on the motor turn over the key work I can hear the gas pump when I turn the key and I changed already the coil pack and spark plug what can it be that my car won't start
It's the immobilizer my car turns on fine the green key flashes a lot and it cranks but doesn't t not turn on is thier anyway I can fix it I'm like 3 hours away from a honda dealership
Try disconnecting the battery for 5 mins and trying again (ECU reset)??
The system consists of the ignition key, immobilizer receiver, immobilizer indicator light, PGM-FI Relay, the fuel pump, and the ECM. With the ignition switch on the immobilizer receiver unit and ECM receive an ignition on command through fuse 46 and the PGM-FI relay. The ECM then sends power to the ignition key transponder through the immobilizer receiver unit. The transponder then sends a coded message back to the ECMthrough the receiver. If the signal is correct, the ECM will then enable the fuel pump by grounding the PGM-FI main relay. The immobilizer indicator light flashes a code indicating the proper key has been inserted. If the key signal is incorrect there is no handshake and no ground of the PGM. The fuel pump is locked out. As you said you hear the pump the problem is not with your immobilizer circuit.
Look elsewhere......
Utah
Utah
Premature vtec
02-28-2013 03:49 AM
