Car Won't start! Possible AEM issue?
Old 06-15-2021, 12:10 PM
flanders's Avatar
Should be easy to check the sensor readings in the AEM software and spot a bad MAP sensor.
IAT, ECT and TPS could also cause problems.
Old 06-15-2021, 07:15 PM
F1TwoThousand's Avatar
Key on engine off. Things should read:
Map sensor 0 psiFuel pressure=base pressThrottle=0%
coolant/air temps =outside temp
If you have key on and reading 5psi or -5psi map pressure you know sensor is bad or wiring backwards! I accidentally switched throttle and map connectors once...
Old 06-16-2021, 07:27 AM
RolanTHUNDER's Avatar
Good point. It reported timing errors for a while since I was tuned. How could timing be bad/off?
Old 06-16-2021, 07:28 AM
I'll take a look asap. I doubt I've ever swapped those connections but stranger things have happened lol
DeathStar5
04-21-2018 07:53 AM
bobonacus
02-20-2016 07:02 AM
conzetts2k
Member S2000 Classifieds and For Sale
06-06-2013 05:39 PM
JohnsS2K
21
08-15-2005 06:11 AM
Quick Reply: Car Won't start! Possible AEM issue?
