Car won't start! Please help! (vid inside)
http://youtu.be/OcT3L-UaFrw
Started just fine at the house. Stopped at Valero for a fill up. When I went to turn the car back on, this is what happened..
First thing I thought was battery. So I took the battery out real quick, took it to AutoZone and the battery checks out just fine and passed all tests. So I had the car towed back to my house and went through the bitch of a process taking out the starter.. Took it to AutoZone and just like the battery, passed all tests and checked out fine. What else could it be?? I was thinking ignition switch but if it was that, wouldn't I not hear a click at all?
EDIT: Car now starts but bad noise coming from what sounds like top of engine @ post #22
try turning the motor over with a 19 mm socket and ratchet it almost sounds like the engine is locked up hows the oil level has the car sat for a long time injectors could have stuck causing hydro lock just brain storming first i would check ground and engine and chassis looks to be drawing a lot of juice when you hit the button check some of this and post results also can you put it in 6th gear and turn motor if i moves but not much take the plugs out and try the starter button again just don't look down the holes just in case the cylinders are full of fuel [you'll put your eye out] good luck
I've noticed with my car that when the battery dies and you have to jump start it with a jumper box you need to wait a little while before the battery has enough juice to crank the motor over. This car has high compression and it needs a lot of juice to crank. Whenever this happens to my car I put the car in sixth gear and try to rock it back and fourth to try to free up the motor a little bit.
I have been driving this car daily without any issues and I just changed the oil a week ago. Oil level is 2 cm below the H mark.
The terminals were fine, no corrosion and they were nice and tight. We even tried jump starting from my parents Odyssey, same thing. Checked a couple of grounds under the starter and the one from the battery. What other grounds or relays could I check? Haven't tried spinning the wheel by hand. I'll try that when I get back from Austin.
Put starter back in and everything back together. Tripple checked all the connections, checked grounds, checked fuses, don't really know what relays to check since I couldn't find any starter relays. The engine will turn counterclockwise with a wrench but not clockwise. I really, really don't want to get the s2k towed to a mechanic but that sounds like my only option now.. Anyone else think of anything?
Would it be a good idea to try to start the engine by rolling the car down a hill and popping the clutch? Or could that further damage things if the engine really is locked up?
