Car Wont Start and I'm 1 day from Fall Colors!!!!
Old 10-23-2003, 09:31 AM
  #41
JDMwhore's Avatar
Did you have Autozone check the alternator too?
Old 10-23-2003, 11:09 AM
  #42
PATHFNDR's Avatar
Is there a relay between the start button and the soleniod? Maybe the contacts are corrodid or the soleniod itself is going bad.
Ken
Old 10-23-2003, 01:57 PM
  #43
Ztec's Avatar
Steve, you have some good advice here and I would bite the bullet with a new battery and after you double check the battery connections check the grounding straps on the car - loosen them and tighten them to be sure and get a good bite - after you install the new battery use some grease on the terminals to prevent corrosion as well as the grounding straps! good luck!
Old 10-24-2003, 02:57 AM
  #44
tenblade2001's Avatar
Update: Car wouldn't start again this morning....changed the battery eventhough Autozone said it was ok. Took about 4 pushes of the start button beofre it turned over.
Old 10-24-2003, 03:07 AM
  #45
w1ngman's Avatar
Gabbed with Raul on the phone last night about this. Curious...if/since its evident that folks (even Honda obviously) sell replacement START buttons, could it be that the Start button is failing???
- Dave
Old 10-24-2003, 03:47 AM
  #46
Ztec's Avatar
was it "clicking " even with the new battery before it finally started?
Old 10-25-2003, 12:50 PM
  #47
moyopoyo's Avatar
Originally posted by RossoS2K
Try another Key.
could be the imobilzer not working right.
yep, this could be it. are you sure you didn't try a different set of keys when it did start correctly? my cousin has the same problem with his. one of his s2000 keys doesn't work at all. all the lights will go on, and the doors will open, but the car won't start.
Old 10-26-2003, 07:53 PM
  #48
Update:
I replaced the battery, and everything worked gfine tiull Sunday morning. We made a pit stop on a drive (I was at FC) and the car died. I had to be push started again. Again, the problem was intermittent. So, I get home, go to the dealer to drop it off, the friggin thing started. I sat for 20min just turning it off and starting it, it cranked up everytime.......yet, I had to be pushed started like 4 times at FC and during the ride home. This sucks!
Old 10-26-2003, 08:21 PM
  #49
AusS2000's Avatar
If you can push start it then it's not the immobiliser. I'd say it's the solenoid or starter motor.
Old 10-26-2003, 08:52 PM
  #50
Thanks Aus.
Quick Reply: Car Wont Start and I'm 1 day from Fall Colors!!!!
