Car wont start after clutch install!
OK guys so i just did my first clutch job on the s2k. I have a lift in my garage but this was my first clutch install ever. I ordered an exedy PP, disk and a lightweight flywheel. I also replaced a master cylinder and slave cylinder.... now once i got the clutch in and installed and everything back together, the d@mn thing wont CRANK OVER at all. i turn the ignition, everything turns on, but nothing... i checked the starter fuse (7.5amp) and i can hear the fuel pump kickin in...
I have a few suspicions-
1- is the clutch release button on the clutch pedal getting messed up so it wont start?
2- Did i screw something up when i pulled the top starter bolt (thing was a B**** to get)
3- this may seem stupid but should i be able to pull the shift fork forward with my hand? like the motion that the slave cylinder does.. because i cant... (paranoid i put the clutch in wrong or backwards lol)
4- is there any way i forgot to plug in a connector on the trans (dont think so because there is only a few....)
PLEASE help me.. i need my daily driver back asap! my cell is 612 655 2711 if anyone wants to shoot me a text otherwise email me!
And big thanks to BILLMAN250 for the multiple writeups on how to pull the trans.
thanks everyone.
thanks everyone.
I would check to see if all of the grounds are connected properly, there is one behind the head and two that go from the block to the frame on the driver side.
I assume the wires on the starter are in tact and you didn't disconnect them, but worth checking nonetheless.
ok i just looked, and from what im looking at there is not a gound on any of the bolts that go from the trans case to the engine? i dont remember there being one on the top bolt... i have the trans all bolted up and cant see all the way up there. any other ideas?
guys, i think i got it. There is a little wire on the starter that i can feel flopping around. like a 14 gague wire what feels like it clips on the starter. i put it on the starter and boom it fired up! now i just have to figure out where on the back of the starter it goes.... Flyin blind!
