Car wont start......
Originally Posted by s2kftw37,Feb 20 2011, 10:07 PM
check for three things compression, spark, and fuel...this meaning the coils and spark plugs for spark portion...also the starter if it is making a noise but nothing is happening then it is probably mechanical and could very well be the gear that meshes up with your flywheel... if it doesnt make any noise when cranking then it is most likely electrical..also check the spark plugs and the coils...next the injectors...the injectors and spark plugs would cause it to turn off when driving too...you however need an oscilloscope to scope both the coils and injectors....
hope maybe that helps a bit let me know!
thanks, Adam
thanks, Adam
maybe your engine is full of gas from that injector,
so your engine is flooded and it wont even crank,
take of a spark plug and try to reach your fingers down into the cylinder
and see if its filed with gas.
Originally Posted by Dumas2k,Feb 20 2011, 09:53 PM
when I try to start the car, it would only click once...
Put a ratchet on the front crankshaft bolt and try to turn the engine a few times by hand. Lets make sure the engine is not stuck somehow. think i read another thread of yours so i think it might be.
Make sure the car is in neutral before turning by hand.
RACECARSON
04-22-2019 10:33 AM
