Car Won't rev over 4k
Try this first. Measure static resistance from valve cover to battery's negative terminal. Set DVM to ohms (DC). I have 0.2 ohm across the cover to the battery. The engine is running fine. You can try moving wires between head and firewall to see if you have a loose connection (ohm readings jump around as you move wires).
Good luck!
Good luck!
