Car wont idle after 2 week storage
Hi all,
My S doesn't get used very much at all any more, it ran fine last time i drove it, 2 weeks later it had problems. On a cold start the revs go to 2k as as normal but then immediately drop to 1k, hitting the throttle makes the engine die. I get CEL P0107/P0108 map sensor high/low
I have cleaned iac & map sensor with no change, i have a VAFC II installed and the PRS reading changes which makes me think that the map sensor is responding and not faulty.
Any ideas what the issue could be?
[media]http://youtu.be/NqybtQrEDYs[/media]
That is with a cold motor, cel is for the map sensor.
I have cleaned the map sensor, the sensor does give a signal to my VAFC and responds. I have clean and tested the pcv. I have checked the coil packs and spark plugs.
The car drove perfectly the last time it was used, 2 weeks in the garage and this issue has occured.
Edit* media tags dont seem to work with youtube.
Forcedbird
05-19-2014 08:11 PM
