Car Wont Crank
Old 05-05-2007, 05:20 PM
prorcracer87's Avatar
Default Car Wont Crank
the car has been fine since i got it last june
i drove it today and it was all good.
i go to mickyDs and when i come back out, it didnt start...fuse #3 isnt blown...i also checked a couple fuses relating to starter motor, and nothing is blown..the start button lights up...i had to have my friends push start it so i could get it home...
fuel pump is working because i hear it, so i think it eliminates the immobolizer
i searched already and havent really found too much info, please help me out a little bit
Thanks
Cliff
Old 05-05-2007, 05:34 PM
revto9k's Avatar
dying battery maybe?
Old 05-05-2007, 05:36 PM
it doesnt even click on the starter motor...everything in the car works too
Old 05-05-2007, 06:56 PM
slalom44's Avatar
If you don't get a click, I'd suspect your clutch interlock. For starters, make sure your floor mat isn't bunching up behind your clutch pedal. Make sure your clutch pedal is enganged all the way to the floor. If it still doesn't work, make sure the clutch pedal is activating the interlock switch.
Old 05-05-2007, 07:04 PM
R3DS2K's Avatar
do a battery test or just check the voltage.. .. and let us know what it reads
also starter relay? since you drove it.. car and relays got hot..
have you try starting it after it got cool??
Soviet
07-12-2015 06:02 PM
matt0488
03-21-2015 03:02 PM
Jag528
02-24-2013 11:20 PM
Andersonracing
02-13-2013 01:57 PM
Quick Reply: Car Wont Crank
