Car will not start -- appreciate any help
Well, I car will not start.
New crank - cam - tps sensors.
Has a spark on all 4 cylinders -- has good compression on all 4 cylinders.
The noid test light showing there is a connection to all injectors.
When I turn the ignition on, the fuel pressure showing 60 psi right away.
The car like to start but no go....
I can't see any cell code because I'm using AEM EMS.
Where else to look????? any idea?
Thanks
Thanks
did you have the motor apart recently ?, if so check that the grounds are all connected, there are two on the lower block driver side, and one behind the head near the firewall, if any of those are not connected the car might not start.
Yeah, I got all the ground hooked up.
Yes I can turn the motor by hand.
I did not do any major engine job except replaced my throttle body.
Both of the throttle body works by the way. The tps measure .30 at rest and 4.5V at wot.
Any connectors that you may have disconnected, I would disconnect again and apply terminal grease. It's possible that if they hadn't ever been apart before that there is some mild corrosion and they're just not making a good connection. Do this and report back. Hopefully it'll solve your issue.
