Car will NOT fire.... Parked good and died
Quick rundown... Parked the car last night running perfect, no issues...
Today, Hop in, Crank... turns over perfect however will NOT fire.
Seem to have good fuel pressure, haven't been able to check spark yet.
Immobilizer seems to be functioning correctly.
Any common problems? Ideas?
I'd say check spark but with individual coil packs, it's highly unlikely that all 4 went out at once.
Is your name Chazz? I'm curious because I've never met someone with the same name as me; although I only spell mine with one z.
I had a similar issue, but mine was intermittent. Sometimes fired right up. Other times I had to wait a couple hours and try again to get it to start. It was bad spark plugs.
Yup my real name is Chazlee (Or Chazz for short)
I am better know as TheChazz(.com) though lol
As for the problem, it appears the car has a leaky injector... its flooded when I go to crank it after cranking after it sits for a long time. I am going to replace the plugs this week regardless... Just hit the 75k mark and its still on stock plugs.
I have read about it a few places online... The injector bleeds into the intake valve while its under pressure and not running. (Right after shutdown)
Swapped in new plugs... Old ones LOOKED fine... However new plugs went in and car fired right up... Ill let the car sit tonight and see fir sure if its solved.
