Car vibrates around 40-45mph after Spring Install
Originally Posted by corners2fast4u,Nov 19 2007, 04:50 PM
I had the same issue launched my car once and pop goes the axle! You need the spacers or I just upgraded to the AP2 axles that are suppose to be 10mm longer. That vibration will get worse if you dont address the issue and I highly recommend that you do drive hard until you do.
There is no difference in length of the axles or thickness of diff flanges between ap1 & ap2. Everything has been measured from axle tip to axle tip on ap1 & ap2 and there is no difference between the two.
I just got my alignment but now it doesnt vibrate around 40-45...but now at 65-70 mph...it seems to vibrate more while trying to go uphills.
all wheels are straight except rear right which is -2 degrees.
EDIT: car is a '00' with 61k miles on it
my springs just came in yesterday, they will be going on over the winter. I hope this can be resolved come spring.
Isnt there a fix to this?
Im gonna reach out there and guess that 75% of the s2k's here are lowered. SOMEONE MUST KNOW THIS FIX!
