Car takes 4 quarts for oil change?
#21
Originally Posted by Skatethesea,Aug 10 2009, 11:35 PM
this is the most ridiculous discussion ever.
Just replace your oil AND filter and refill with 5.1qtz like Honda recommends and gone on your marry way. Check oil level every couple hundred miles.
repeat every 3k miles.
If you make sure you allow for all the oil to drain out, change your oil filter and put in the drain plug, a dipstick reading on H or near it with only 4qts of oil tells me that there is something wrong with the dipstick or the way it is set up.
I'd put 5.1qts and make a note of how it reads on the dipstick 15 minutes after initially warming up the car. I would then make sure it reads this way (15 min after turning off the engine) on subsequent level checks.
VTEXTC
04-21-2003 03:36 PM
