Car is stuck in Reverse Gear!
Old 01-15-2012, 11:52 AM
Dsteven21's Avatar
Default Car is stuck in Reverse Gear!
I live in nj and its very cold now around 20s, so yesterday after leaving work i see my car has ice on it from the cold. I let it warm up untill 3 bars (AP1). Once its warm i attempt to put into gear but it wont move into anything, it takes 15 min till it budge and i get home, the whole way it gave me problems into first. Then today i changed the clutch fluid with my dad he goes and drives it. When he returns he reverses it into my garage and now its STUCK . Im guessing the is air in the fluid because it was low when i changed it? any help guys how much to fix it. I just bought her dec 25 with 90k miles
Old 01-15-2012, 11:58 AM
Dsteven21's Avatar
also when i pressed the clucth pedal it feels a lot softer when the car was off just now
Old 01-15-2012, 05:57 PM
OneSilverS2k's Avatar
make sure all the air bubbles are out of the line, also have you messed with the rod location under the dash to the CMC? Honestly, I have changed my clutch fluid a few times, and there was air in it still. Also I use synthetic clutch fluid, and brake fluid on S2000's. Does it ever feel notch, when you press the clutch in?
Old 01-16-2012, 10:56 AM
Dsteven21's Avatar
no i havent messed with the rod location. i bleed the fluid today but im not sure how to get bubbles out. the clutch is still soft to me
Old 01-16-2012, 11:09 AM
t3am 83rd's Avatar
Check around and see if clutch fluid is leaking anywhere.
Old 01-16-2012, 11:29 AM
Member
zdave87's Avatar
Received 1,137 Likes on 1,013 Posts
Look on the bright side, at least you'll be able to rewind the odometer.
Old 01-16-2012, 11:37 AM
Dsteven21's Avatar
there is no leaks
Old 01-16-2012, 12:08 PM
s2cho's Avatar
did you bleed it like this
http://forums.s2kca.com/showthread.p...t=clutch+fluid
and after bleeding you should MASH THE CLUTCH. im talking your hardest. a few rapid pumps will get the pressure back. thats what fixed mine.
Old 01-16-2012, 12:12 PM
SgtB's Avatar
Flush the clutch fluid. Bleed it of air. If the fluid is old the water in it is acting up in the cold.
Old 01-16-2012, 12:43 PM
Dsteven21's Avatar
im going to try it again like the thread but its getting dark already dam you NJ
Quick Reply: Car is stuck in Reverse Gear!
