Car starts but won't move
Old 09-01-2009, 10:00 AM
vtec9's Avatar
So, if you can put the tranny into gear, engage the clutch (release the pedal), and don't give any gas.. it won't stall? Sounds like your clutch is tooooooooooooooooooooooooooast
Old 09-01-2009, 10:34 AM
Distracted S2000's Avatar
yeah thought so... Time for a aftermarket clutch!
Old 09-01-2009, 07:08 PM
PhoenixINX's Avatar
Originally Posted by deathsled,Sep 1 2009, 12:41 PM
Otherwise it sounds like your clutch The disc is either so worn that it won't engage now (did the car drive normally last time you drove it? no slipping?) or I guess it's possible for for the mechanism to be stuck in the disengaged position.
THIS sounds more likely... a clutch just doesn't die. You're always going to have indicators to failure on a daily driver.
How did it drive the day before? The week before? Need more info before...
Old 09-02-2009, 07:12 AM
rob-2's Avatar
If it slipped the last time you drove it, it's been slipping for a while. Get a new clutch.
Old 02-09-2018, 05:03 PM
KellyC's Avatar
Default Mine too
Originally Posted by Mister Jew
when you let off the clutch and give the car gas what does it do?
does it move a little? does it just rev up?
weird problem never really heard of it.
did someone steal your driveshaft?
Same thing is happening with my 2003 h0nda s2000. I went away for a month came back to dead battery.. Got it started put the car in gear and it just spins the tires... Its parked in gravel and it just digging a whole... It idol rough... B4 i went away i had the plugs changed but not the coils.. It was running siper rough and like not much power..didnt barely move in reverse.. Plugs xhanged made a huge diff but not totally..today i couldn't get it to move... It did dtall out if i gave it lots of gad .
What could it be?
I'm a female and don't like mechanics..they always try to soak me. I learn a lot from yoy guys
Kelly
Old 02-09-2018, 05:48 PM
windhund116's Avatar
Received 1,533 Likes on 1,037 Posts
Sounds like clutch. I'd go with OEM stuff.
Good luck!
Old 02-09-2018, 09:36 PM
Slowcrash_101's Avatar
My head hurt reading that, probably fuel related. Did you leave the tank near empty on your trip? If not fuel pump, then clogged injectors. A lot of us are mechanics.
Old 02-10-2018, 02:31 AM
Coloradocurt's Avatar
Just a general comment, but when someone starts such a "mystery problem" thread, it would be helpful to the community if they would follow-up by posting some sort of conclusion post with what the cause and solution was. Just saying.........
Old 02-10-2018, 03:33 AM
Billman250's Avatar
Received 1,396 Likes on 837 Posts
Guys this thread is 9 years old.
Old 02-10-2018, 09:48 AM
jts09's Avatar
I've caught myself more than once typing a reply to a post only to see that it is very old. I always have to check.
Quick Reply: Car starts but won't move
