Car starts anytime except during the morning
It's been pretty chilly in the past 2 weeks here and I noticed a trend when I start my year 2000 S.
In the morning (around 7ish am) I go to work. I start the car and it seems like the engine is having a hard time to start. It cranks and makes the usually clicking noise but just sounds like it doesn't have enough juice to start the engine. So far I've been very lucky in starting it with the first push start.
Here's the weird part.
During lunch time and when I leave work (5pm), I start the engine w/o any problems. The car will start with the push of the button. No struggle at all.
I've asked a few friends and they said it was the battery.
So I took the car over to my good local mechanic and he said battery has full juice. He tested the battery w/ my engine on, off, and also engine off w/ headlights on and said its full.
Any idea what else it can be? If worst comes to worst, I guess I can run to my local Coscto and buy a battery. If it fixes it, then I'll keep it. If not, then I'll return it since they have the best return policy.
And does Costco sell any good battery? Right now I'm running Energizer 51. I've had it for about 2 years.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Did your mechanic load test the battery? A bad battery can still display good voltage and power the components in your car (lights, stereo, fans) and not have enough cold cranking amps to get the engine turned over in the morning. I would buy a new battery.
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Yeah, how cold is cold? How many times during the day is the car started? Do you drive to lunch? Does the car sit from 5:30 pm until the next morning? What draws do you have on the battery, like an alarm system? What's the published lifespan of an Energizer 51? It sounds like a weak battery to me.
Basically my mechanic brought out a battery voltage meter and tested my battery in my engine bay.
The battery was never disconnected nor taken out of my engine bay.
How many times during the day is the car started? started about 3 times, once in the morning, once during lunch, and once to drive home. And if I go out, 2 more times for a round trip.
Do you drive to lunch? yes
Does the car sit from 5:30 pm until the next morning? usually, I have another car to drive to grocery store or mall.
What draws do you have on the battery, like an alarm system? no alarm system, just OEM lock/unlock FOB from Honda.
What's the published lifespan of an Energizer 51? don't know. Did a search for Energizer 51-500e w/ no result.
man, drive the car over to my place and you know i'll help you out. just give me a ring if you'd like me to take care of it for you!
you should know im good for it
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
