Car stalls coming to a stop
Old 12-07-2008, 07:45 PM
subsoniic's Avatar
Default Car stalls coming to a stop
Hey guys, I have an unusual symptom, I tried searching but no luck, so any input, feed back is greatly appreciated. So the symptom usually occurs during first start up of the day, or morning what happens is my car would stall coming to a stop, then id have to start it up again, the stall is very suttle and not even harsh..i dont even notice it until i try taking off..could it be the map sensor ? maybe my dirty CAI filter ? ..kinda annoying..help me !
btw -
brand new battery, new alternator, new coil packs, new plugs for reference. all about 2,000 ago. car is always fully warmed up b4 taking off
Old 12-07-2008, 11:57 PM
funkemonke's Avatar
take off your map sensor and clean it, ziptie it, clean out your iac, oil & filter change, valve adjustment (intake .008, exhaust .010).
you dont have to wait till the car fully warms up before driving. start her up and drive. its better.
Old 12-08-2008, 07:16 AM
AngryTurtle's Avatar
You have to push the clutch in.
Old 12-08-2008, 10:03 AM
Burgman's Avatar
Dirty/sticking idle air control vavle is the most likely problem.
Old 12-08-2008, 10:31 AM
martin j's Avatar
As above.
Old 12-09-2008, 05:40 PM
subsoniic's Avatar
Thank you guys.
Old 12-11-2008, 07:32 AM
da_wesmeista's Avatar
I had this problem after installing my cai, later I found out that I had two of the vacuum lines switched. Try finding a picture of the vacuum lines and make sure yours are installed properly.
Old 12-11-2008, 08:07 AM
AeroS2000's Avatar
ECU is trying to learn the new parts. this happened to me when my battery died. i kept my car alive by givein it throttle and drove fast for a while untill the car is stable
Old 12-11-2008, 06:55 PM
Kirpich's Avatar
I had the same exact problem when my Missing Link got loose. So the intake manifold might have a leak somewhere, like a bad or loose hose, including the PCV hose at the valve cover.
Old 12-11-2008, 06:57 PM
Banned
sbrodacz's Avatar
idiot
Quick Reply: Car stalls coming to a stop
