car stalled and wont restart battery
hi
im gonna tell you my story
i installed. turbo,did battery relication aslong with fusebox
i went for a ride , after 15-20 min the car stalled while running... i was not able restart it.. i started it on compression..when i got home s,i shut the car off and restart it again,it was okay.
did this 5 time,each time car restarted fine
what could cause my car to stall? i tought to the battery because the battery went down many time before,dso i brought it to canadian tire and they checked it ,they told me the battery was good...
I noticed, some time with a intelligent charger,it write ´´check´´ connection with my battery on the car
if i unplug it it okay,it gonna start charging,
iif i put back car cable on battery and put the charger again on
it ,it gonna start charging too...but something it can tell me ´´check´´..
one time i charged the battery,the battery went to 80% ,the charger "f@#ked" ,i reinstalled the charger right after on the battery,it showed 100% charged
so whats my issue!!?! it is a short in my car ? or bad battery showing good on a testee!? (like said the battery when down many time due to a short on my car that i found already before)
thanks
thanks
