Car smoking crazy only in VTEC!?
Old 12-01-2006, 11:30 AM
Dolemike's Avatar
Default Car smoking crazy only in VTEC!?
Ok, so pretty much all of a sudden my car smokes while only in VTEC now. I have 137k miles on MY01 and the valve adjustment hasnt been done yet... I know it needs to be done... Im kicking myself in the ass over that b/c I know better. Anyways, Im going to pull the plugs this weekend and clean them off and see if that helps anything. While I know seals and rings will cause a car to smoke I just don't feel that this is the cause. Maybe because the car is only smoking in VTEC and no other time. My car has always run rich as hell since I've owned it but I don't think its running THAT rich to make that much smoke. Could it be that my car could be smoking from the valves being WAY out of spec? I would attempt to do my own valve adjustment but I'd feel much more comfy with someone who knows what they're doing overlooking things and I can't take it to a shop b/c Im strapped for cash.
Old 12-01-2006, 12:53 PM
djpeak10's Avatar
How is your oil consumption between oil changes?
Old 12-01-2006, 02:21 PM
RadioZero's Avatar
sounds like you don't maintain your vehicle. valve guide seals are probably toast.
Old 12-04-2006, 11:04 AM
Dolemike's Avatar
I burn up about 1 qt. every 1k miles or so. I do maintain my car, I've been strapped for cash lately though which is why the V.A. is as overdue as it is. If valve guide seals are toasted how much should I expect to fork out to get them replaced?
Old 12-04-2006, 12:06 PM
thetz99's Avatar
i'd recommend a set of krank vents which will seal your engine better and keep oil from slurping through the pvc valve into your intake manifold.
Old 12-04-2006, 01:20 PM
djpeak10's Avatar
He beat me to it. The only reason I have not done this mod yet is because as of right now I don't burn any oil during changes.
Old 12-05-2006, 08:30 AM
Dolemike's Avatar
Yea, Ive had someone else recommend that to me as well. I will probably order a set really soon. So eitherway it goes, this is a temporary fix at best? Can anyone give a ballpark on how much replacing the seals gonna run me?
Old 12-05-2006, 10:52 AM
thetz99's Avatar
Maybe you should do a basic compression test and then a leakdown to see where your engine heath is. Otherwise you're just spinning in circles.
Krank vents will help your engine in either case.
Old 12-05-2006, 06:36 PM
f20kills's Avatar
When my car smoked that bad and ate that much oil, I had all four cylinders with scored walls. Compression checked out fine too, 210 accross the board.
Old 12-06-2006, 08:50 AM
Dolemike's Avatar
F20kills, so whatd you end up having to do to remedy the problem?
Quick Reply: Car smoking crazy only in VTEC!?
