Car running like crap!
Originally Posted by BatmanCR,Aug 11 2009, 11:34 AM
When i took mine yesterday they called me and said that i had a bad ignition coil. Im having the same symptoms as you.
I'm guesing u had code p300 p301 p302 p303 p304 and p305? Misfire misfire cylinder 1 2 3and 4 and mulitple misfire? Check and see if the egr valve is stuck open or the cat is clogged. Let me know where the power is as far as RPM and how it idles. Egr valve wouldn't typically throw a code. Misfires thesedays are usually cosed my a timing or af metering sensor. If it's running that rich u can get a flame you should have some sort of information on a circuit out of range code. Pm me
for my number I'll try to help ya if your interested.
