Car pulls to the right under power
My car pulls to the right under power. It's not severe as and can be corrected with a little steering input, but definitely noticeable. Once I get off the gas the car shifts slightly to the left. The alignment is fine (had it checked) and I'm running relatively new tires (less than 3k miles 595 RSRRs) so I'm not really sure what could be causing this. My alignment guy suggested checking out my diff mounts after he noticed the pull; looking to crowd source some other suggestions before I crawl underneath the car this weekend.
Thanks
Thanks
Yup, check your rear tire pressure. First time it happened to me I thought my rear end was going out.LOL Just low pressure in one tire. It's like a built in rear tire pressure monitor.
ROD
ROD
Thanks
Thanks
Most likely cause is rear tires aren't the exact same diameter. As states, these cars are hyper sensitive to this. Most likely reason for size mismatch is uneven tire pressures.
But it could also be manufacturing tolerances of the new tires, especially if they were not made in the same factory. Tire Rack has had to replace tires on a handful of occasions due to this.
Check your tire diameters. Once you.are sure pressures are identical, measure diameter of both and compare. Get some string that doesn't have any stretch, wrap around tire center, mark string overlap. Do same other side, make sure same exact size.
I can attest to the rear tire pressure effect. Tiny leak from a puncture in one of mine and the car was squirrely even in normal driving. Once the leak was patched from the inside all was well again. Hopefully it's this simple.
-- Chuck
-- Chuck
The S2k is very sensitive to ANY differences between R and L rear tires.
If you are running a square setup, try swathing R and F tires. If you aren't switch L and R rears. If it changes, it's due to some tiny difference between the R and L rear tires.
I had this problem after replacing one tyre with one of the same make and type. I could actually change lanes just by accelerating and backing off. Swapped tyres L+R and it swapped directions. Turns out although the older tyre wasnt very worn the newer one was of a 'new and improved compound' and was a big part of the problem, replaced older tyre and the problem went away.
