Car pulls to left under acceleration and then back to the right with decel.
Good luck!
Originally Posted by gpep77' timestamp='1412779463' post='23361289
Yeah I remember reading somewhere engine mounts could cause these symptoms. I will definitely look into this.
Good luck!
Leaking crankshaft pulley seals can cause this, too. FWIW.
Good luck!
Good luck!
How did they check the brakes?
Jeez these threads get off track.
Your problem is in the rear tires, 99%.
Tire pressure, size, brand, age, and wear must be identical.
If all these check out, you have a defective tire.
Swap tires left to right, if the pull changes direction its the tires.
